Amana AFD2535DES French Door Refrigerator Logo
Posted on Mar 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The food side not geting cold I set up the control nothing
I have two doors refrigerator the freezer side working find the food side not cold is stay hot
Anonymous
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Apr 01, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1066
Questions
0
Helped
496826
Points
3071
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
3helpful
Fridge doesnt stay cold
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
2answers
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
My freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Freezer side cold, food side warm not working
3 possible problems.... Machine is possibly not defrosting (if this is it, eventually the freezer will not work as well) The damper between the two sides is possibly not operating, or the fan on the freezer side is possibly not blowing the cold air into the fresh food side.
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
