I don't know if the above model is 100% correct, but it is a 46" LCD screen purchased in 2011 (sometime late in the year). TV has never had problems before. Only recent change is I installed a new DISH receiver as the other one faulted out about a month ago. Think I got the HDTV settings correct (1080i / 16x9 ratio) but not sure. I don't think that's the issue but not sure what to do at this point. Flickering makes it almost impossible to watch, though there is not any problem with the sound.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure. (1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out). (2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen. (3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered). (4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats. (5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life. (6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead. (7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight. (8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem. (9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity. (10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
SOURCE: samsung 40 inch lcd mode not supported
My 360 and samsung hdtv worked fine for about a year and now im getting the problems mentioned above, not sure if its a console/cable/telly problem but i did the following (temporary?) fix
Unplug your 360 and plug it into another television set, it seems to reset/calibrate itself somehow and then when you plug it back into your samsung tv it will work - mine did but for how long i dont know.
J Bizzle
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
