The second hand jumps back and forth but not in 5 second jumps - in 1 second jumps.
SOURCE: Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance. Donald McPherson Certified Watchmaker AWCI www.finewatchmaking.com
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4-5 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
SOURCE: Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
SOURCE: My Tag Heuer's second hand sticks and jumps in 4
Has your display got a flashing display "BT" at the right hand side of the display? If it has, then it means that the battery needs replacing.
