I turned the tv off last night. When I got up this morning the red stand by light is not on and the tv will not turn on. I even changed batteries in the remote. Still no power for the tv. Usually the stand by button is on when the tv is off.
A lot of people are confused about turning the TV 'off'. If there is a light showing when the TV is 'off' it is merely on 'stand-by' and not truly off. Off means being physically turned off by either the switch on the set or the mains. using the remote to turn 'off' the TV will not turn off it will only put the set into stand-by mode. In many cases if the TV is in stand-by mode, and then switched off, when the set is turned back on, it will still be in stand-by mode, and will need to be turned on with the remote. (even if you unplug, in some cases) All TV's are different, so will operate differently of course.
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
SOURCE: TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
SOURCE: 32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: Turned Panasonic Viera Plasma tv
Red light flashing indicates some hardware/ circuit board failure in tv, please count how many times red light flashing after long pause as it is an error code that has info about specific section failure in tv.
Let me know how many times red light is flashing in this Panasonic TH-42PX60 tv to provide you helpful info to solve this issue.
Thanks.
