Door ajar light is also coming on every few seconds but all doors and hatch are closed
Sensor/switch in door pillar has a broken wire or somethiong adrift,door locks could have two problems the switch tripping the relay or the actual door lock mechanisms within the doors need lubricating with engine oil .Take the door panels off and oil with a proper oil can and none of that **** spray stuff that dries out
For
Doors not getting open with remote or key problem,there are help
links provided below.Click the link below to go through its
procedure and troubleshoot the problem:----
drivers side front door will not open from
inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will
not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door
locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car
Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control
Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not
working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with
Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace
Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will
not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
Door ajar light stays on but all doors are closed. Door ajar warning bell sounds off and on but more so on. Power locks grind continuously as if the doors are trying to relock themselves every few seconds. Inside lights flash off and on. The problem seem more pronounced when it is raining. Sometimes windshield wipers will come on by themselves when hand have been nowhere near the signals or switches. This is particulary interesting in the summer....!
