Exercise & Fitness Logo
Suzanne Millership Posted on Apr 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an everlast treadmill Jx-269e showing error e09. Any idea what to do about that please?
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Apr 04, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076015
Points
34431
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless youI have an everlast treadmill Jx-269e showing error - 65723e8e-6bcc-4a02-900e-e9fa117bb428.gif
  • Suzanne Millership Apr 05, 2013
    Thank you for taking the time to write such a detailed response, I appreciate it.
Hi there. I have an Everlast treadmill. I did a running mat replacement and I used it for about 10 minutes then it stopped and showed E6 Error. Any help will be highly appreciated.
Question edited for clarity.
Question moved to 'Everlast Fitness' category.
E6: Insufficient power To clear: Check if voltage is too low or if the controller has been damaged. Replace the controller if necessary.
https://www.dyaco.ca/manuals/Treadmills/Everlast/16005606510-EN.pdf
https://www.google.com/search?q=everlast+treadmill+e6+error
E2 code on everlasting treadmill
The error code E2 is indicating that the console is not receiving any information from the reed switch or optic sensor. This is because the treadmill belt is not turning. If the motor would run you would lose the E2 error.Oct 31, 2007
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
I have a roger black treadmill and E09 appears on the led screen. Nothing responds when I press buttons
E9 treadmill error: connection error
1. Check all wiring from Base to console.
2. If E9 still there replace controller
Everlast treadmill JX-269E error code E02
If you wish to get some details; check the site linked here. Pull up older posts..
http://electro-medical.blogspot.com/
2answers
E09 code on pro fitness treadmill
My motorized Treadmill is showing error E09 how can l clear the error?
E09 code on profitness treadmill
Return it. Get your money back. Buy a real treadmill.
9helpful
I have an error message on my powerjog treadmill
jx 100 powerjog displaying self diagnostic error-how do you find what the error is
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
