I have a 4 gb sd card loaded into my sd 800 is canon camera. When I connect my camera to pc via usb cable and right click on the camera icon and select import, the camera shuts off after a while.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Folder missing from SD card
Transfer the folder to your computer, along with any other pictures you want to save. To do this use a card reader, not the camera. Then click and drag the folder onto your desktop. After you will format the card using your camera (press menu then under the setup tab [yellow colored]) - this will delete all the pictures on your card so make sure they transfered onto your computer. Take a random picture on the camera to generate a new folder. If you want to put the pictures back onto the card so you can view them with the camera (not necessary), you should put the card back into the card reader, then open the dcim folder. you will see a folder which says Canon###, copy that name and make sure it matches the name of the folder you previously copied onto your desktop. click and drag the folder back onto the memory card to replace the existing folder in there (the random picture you took will be over written, so if you liked it transfer it first). That should have covered it...i know i made this very wordy, sorry, but i'm used to explaining these things to my parents who don't even know how to turn on their camera.
SOURCE: Can't download images from Canon SD1100 to computer
Hi and welcome to FixYa.
Sounds like your reading right from the manual. <grin>
Try this.
Connect the camera to the computer via the usb cable. Set the mode switch to playback and press the power button, then:
on your pc go to Start>All Programs (or Programs)>Canon Utilities and find Canon Window. Double click on it and it should fire the program. Let me know if you have any problems. If not, feel free to rate my solution.
Rob
SOURCE: Connection problem with Canon 450D to PC.
Use a card reader to download your pictures to a folder you create on your desktop.
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
SOURCE: Unable to import photos from Rebel XT to iphoto on mac..."busy"
Try changing the "communication" setting on the camera from "PC Computer" to "PTP"
Menu > Tools2 (wrench/hammer/2)
Communication = Print/PTP
http://docs.info.apple.com/article.html?artnum=75336
