GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2 Logo
Posted on Mar 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing display screen time
How do I change the display time on the Marquette Eagle 4000 Pt monitor?
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Jun 03, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
Helped
40514
Points
119
I have a user guide to help do this if it is still nessesary.
Requiero diagrama de fuente de alimentacion
you can visit this web and you can download service manual for eny devices : http://www.frankshospitalworkshop.com/equipment/ecg_service_manuals.html
1helpful
My eagle 4000 is 120volts then it is accedentally plug in to 220volts. it blown the fuse at the power supply pcb board then i replace the fuse 10amperes but it still blowing.what could be the problem?
There will be an MOV (metal oxide varistor) After fuse. This MOV is rated 125v. When you plug the machine in to 220v supply this MOV will become shorted and its blows the fuse to prevent further dameges to the power supply. Replace the MOV and then insert the fuse. I have added the image of MOV here. It is placed parallel to the AC mains supply rail after fuse.
Ajin
2answers
Simultaniusly on and off
hi,
You have to check the battery of you monitor . If the battery is short then this problem can occur.
ok
I need the service password to reset the unit to factory defult setting
hi,
remove the AC power. then remove the battery from the machine. reinsall the battery after 15 minutes. then power on. it will be at factory settings. if u need its service manual pls contact me through fixya . for removing battery watch the pictures bellow.
ok
It keeps rebooting
when the battery goes completely dead it looses its software. The only way to fix this is if you have a copy of the original software and install a new battery. With these units it is a good idea not to leave them unplugged for a long period of time. It is a good way to loose all the data.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com. We have a biomed on staff with 25 years experience who is able to fix this issue.
I HAVE AN EAGLE 4000
Most likely a bad battery which made the system loose the software. Small chance that the screen is bad. If you connect a pulse ox and you hear the hear rate it is a bad screen. If you don't hear it you will need to get a copy of the software and a new battery. GE does not support these anymore so you should contact a third party if you are not able to do it your self.
1helpful
I have a monitor marquette eagle 4000 no work with batery pack
After the battery goes dead in these units it earases the internal software. You need to have the software reinstalled with is a rather tricky thing to do.
Top GE Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a GE Medical Expert? Answer questions, earn points and help others
