Question about Panasonic KX-TG1033S Cordless Phone
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I have Comcast digital voice for my phone provider. I have experienced problems with my phone for the past year, most of which was related to Comcast (6 service calls since July 08). However, yesterday, after the phone rang twice, there was no one on the line. When I hung up, there was no dial tone. I reset the modum and still no dial tone. When the tech came out, he unplugged the phone from the power source, and the dial tone came back. I also repeatedly have dropped calls (about twice a week) and can hear an echo at times. Is it the phone or is it Comcast?
    Top Expert:
  • Panasonic Master
  • 85,222 Answers
I am sure that is a service related issue and no the phone itself.
Posted on Apr 26, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Posted on Mar 31, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: Dropped calls - Model KX-TGA101S
Try replacing the phone cable, and check that is well plugged into phone rj11 connector.
If it is not the cable call comcast.
Posted on Jul 31, 2008
Anonymous
SOURCE: GE MODEL 28811 DECT 6.0
I have this same problem. Still don't know how to fix it.
Posted on Aug 12, 2008
Anonymous
SOURCE: we have had a panasonic
We have this model also, and have exerienced similar problems. Try disconnecting all of the phone lines for that ph number, for a minimum of 30 seconds. Reconnect and the line should be functioning again. It always works for me.
Posted on Sep 12, 2008
Anonymous
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
Panasonic DECT 6.0 cordless phones system has begun dropping calls after first ring also won't take messages
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Apr 27, 2017 | Panasonic Lands Phones
How do I stop the red light from blinking
You may have unanswered voice mails or a missed call. Do you have a stutter dial tone from your telco provider, it means the same thing.
Sep 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
When using phone I cannot call out , it gives me a fast dial tone , but I can get incoming calls
Does the fast dial tone persist, or do you get a regular dial tone after a couple of seconds? If the latter, then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 16, 2014 | Panasonic High quality max 2.4 ghz phone...
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
How do i stop the blinking blue light on my ge 6.0 phone?
hi... first of all clear all voice mails from the provider (Comcast digital voice service allows you to do it via web),  and ur dial tone will returne to normal sound and ur light indicator will stop flashing....
thank u rate me
Feb 09, 2009 | Uniden Cordless Phone
DIAL TONE CONTINUES DOES NOT CEASE
Have you tried plugging and then plugging the phone back in. This should discharge all static electricity.
I had the same trouble once. If you are using a service such as Comcast Digital Voice, then restart all equipment (this apply's to VOIP services also). if it still persist then try a different phone. If it still persist then contact your phone company and explain all the solutions that you have tried.
Feb 04, 2009 | Panasonic KXT7885/-W Wireless Telephones
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
1,841 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
