Microwave oven door lost support after loud twanging noise....diagnosed to torsion spring either breaking or detaching......
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: Microwave door comes down hard and fast. Lost it's
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
Normally
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
SOURCE: how to replace torsion spring
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
