I have a verbatim external hard drive 1TB,when I connect the hard drive to my loptop I dont see him, I see only the usb cable tell my why is happening this,I have a problem in hard.
thanks but I understand that it is not posible because is badthanks but I understand that it is not posible because is bad
AnonymousApr 01, 2014
I have installed and copied and pasted to this Verbatim ExtHD before. Now my Asus Netbook says I have to format it. Wondering if I need a better USB cord to connect them to together. Or what?I have installed and copied and pasted to this Verbatim ExtHD before. Now my Asus Netbook says I have to format it. Wondering if I need a better USB cord to connect them to together. Or what?
You can't post conmments that contain an email address.
Im not sure what computer you have, but whenever I use an external hard drive on my computer, an icon either shows up on the toolbar, I dont think in your case thats happening or you would have obviously seen it, however if you have a start or home button on your toolbar on your regular desktop location then you can click to open your computer menu e.i. control panel, word, games,...etc.. look for your "computer" file, click to open, then look for "Hard Drives" or "Devices and Storage" also check and see if anywhere in those menus if there is a "Removable Devices and Storage" tab, if you find these menus and verbatim 53018 doesnt show up in any of your menu tabs then try creating a file on your computer and saving it to your hard drive in the "Save" file location, if its connected properly then you should see a message screen that asks you which location would you like to save your file, it should list all possible storage locations and hopefully Verbatim 53018 is listed.
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
An external hard drive is a normal hard drive with a converter to change it to USB. If you have important information on it, you could open it up, and connect internally to your computer, however, opening it will (almost always) void the warranty.
I'd recommend contacting whoever sold it to you, and asking them: 1) If you can open it up, to connect it internally, to get your data off, and 2) For a replacement.
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone. Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
it is very bad,neitgher another laptop see him
can i save some data from him and how
