I have scrolling horizontal lines on my hitachi projection television.The television is approx. 13 yrs. old, but we have never had any problems at all with it. The lines are not always on the television. I have direct tv with satellite. Could it be an interference problem, grounding problem or a television problem? How do I get rid of these scrolling horizontal lines?
SOURCE: Rolling horizontal lines. Changing picture shape like fish eye lens view.
the magnifing unit is going
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
SOURCE: Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
SOURCE: to fix or not?? 1990 Hitachi big screen
Sorry the answer is no. If the rolling pic was the only problem you had then yes throw a new signal board in and move on. In this case your picture not being as sharp as it used to be will also be tubes going bad..18 years not a bad run on three tubes that run extremely warm. Have fun on your upgrade to lcd or dlp proojection this will cost less than the fix of your tv.
Josh
SOURCE: Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
