Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
Please be informed that any hardware device needs a driver software to run within a PC, and the driver software depends on the Hardware Make/Model and the Operating System software you are using in your PC to operate it.You will get the Driver software of any hardware within the CD provided with the hardware part at the time of its purchase. The hardware may be an entire PC,Laptop,VGA card, sound card, LAN card,webcam,printers etc.
If you do not have the CD or misplaced it somewhere then you need to download the driver software to get going. Thus you need to know all the above information to get the exact software your PC needs. As you have not mentioned the Hardware Make/model and Operating System you are using, i am unable to give you the direct download link.
However you can download the same by visiting the 'software downloads' section of the website of the hardware brand you have purchased. You just need to Google the name of the brand and visit their website and search for the download section.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
