Brand new weed eater just bought it. but it keeps bogging out at full throttle or when i put in on heavy load use. any hints?
SOURCE: my Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
SOURCE: Trimmer bogs down when throttle
Hi David, bring the high speed screw out until it accepts throttle, regards Phil.
SOURCE: trimmer head not functioning right
sounds like the inner drive cable has broke inside the shaft that drives the trimmer head.
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Open the Low side Air/Fuel Mixture needle (the one closest to the engine) about 1/8 to 1/4 turn counterclockwise.
