The dishwasher turns on and runs for 15 minutes then stops, i,ve checked hose is clear, water is on,fuses, drain is clear, delayed start is not activated. Please help.
Check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
SOURCE: Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
SOURCE: Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
