AliExpresshttps://www.aliexpress.com > item
Buy Lasika K-sport F60 LED Backlight Watch with Week / Alarm Clock at Aliexpress for . Find more , and products. Enjoy ?Free Shipping Worldwide!
US$5.00
Watch electronic sports K-SPORT lasika. Characteristics of: The size of the case is 48*48mm. Material-plastic. Light-Yes. Stopwatch-Yes. Color screen-Yes.
US$5.79 · ‎In stock
In anlog watch pull crown to it's final click and turn it untill date drop to next date that's mean am (midnight - 24 Hr) then set the time accourdingly,,
it the watch is digital then on time setting mode it will give you option for am of pm ,, which can be chose,
hope that will help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
on the back of the Starck+ PH-5016, directly in the center, is a button much like one that would be on a digital watch. Use a pen or other pointed object to depress that button and the hands will spin. Release the button when desired time is achieved. Only runs clockwise, so setting it back an hour might take awhile, but it will eventually get there.
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
hold the left, bottom button (marked ....) for a few seconds....then
press the top right button (marked with 1 dot) to change between the
hour, minute, date etc. use the bottom right button to advance the
flashing number, and when finished setting time and date, use the
bottom left button to stop the numbers flashing and return the watch to
normal. hope this helps,
