There are three colors on the screen all shadowed and images are blurry. the colors are blue, green and red or yellow? TV was manufactured in May 2004.
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move tSony KP-51WS500 Rear Projection TV colors are dist - 2c07611.pngdirections your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
This is a convergence problem that can be as simple as poor connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself.
Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
