Question about Sony Office Equipment & Supplies
Error p02 canon mg2120 - Sony Office Equipment & Supplies
5 Suggested Answers
6ya staff
SOURCE:
Antony Cassidy
  • 36 Answers
SOURCE: My Canon Pixma MP250 is showing the error code P02.
There are some good videos here on how to fix this issue
http://www.youtube.com/watch?v=JCMrI8HZPKw&feature=relmfu
Posted on Apr 06, 2012
  • 6046 Answers
SOURCE: My Canon PIXMA MG2120 stop printig last night, Gave me an error message 5100.
When the 5100 error happens, there are a few things you can check. The error means that the ink carriage isn't moving across the printer properly. First check if any ink cartridges are not properly seated. (Open the front cover and the paper output tray and then the paper output cover of the printer while it is on. The head cover should open when the cartridge carrier moves into the Fine cartridge replacement position. Then you can double check the cartridges.) Close the covers and check if the problem has been resolved.
If the cartridge carrier doesn't move to the replacement position or the cartridges are not the problem, then you need to check for a jam (paper or other object) blocking cartridge carrier. (Possibly the block is between the cartridge carrier and the "home" position for the carrier.) Turn off the printer and unplug it from the outlet. Open the paper output cover. Avoid the clear film but check for any paper or foreign objects. Move the cartridge carrier to the different sides of the printer to make sure that nothing is under the carrier. Pull any paper slowly and steadily to minimize tearing the paper. You'll have to remove all the small pieces, if they are present. (Note: some paper might have ink on it and thus harder to see. Use a flashlight to help check the corners of the printer.) Check the paper input area as well. After clearing the jam, close the paper output cover, replace the paper in the input tray and check the printer again.
If this doesn't resolve the problem, try resetting the printer. Turn off the printer. Disconnect the data cable if you use the USB cable. (I like to disconnect the cable from both the printer and the computer.) Unplug the power cord for at least 10 minutes (from the outlet and printer, if possible). Reconnect the power cord and data cable. Turn the printer on and check for any error messages.
The next possible problem is a dirty encoder strip. Turn off and unplug the printer. Open the paper output cover and locate the plastic strip. If there are any smears on the strip, use a neutral pH detergent (2-3 drops) in a 1/4 cup of water. Moisten a cotton swab in the detergent solution and squeeze a bit to remove the excess water. (You don't want to drip the water inside the printer.) Wipe the swab across the encoder strip. Use multiple swabs to clean the entire strip. Do not touch the metal rail or push the encoder strip. Check that the encoder strip isn't dislocated from the springs on the ends of the strip. Take another set of cotton swabs, moistened only with water, to remove any detergent residue from the strip. Dry the strip with additional (dry) swabs. Let the printer dry before closing the paper output cover. Then plug in the printer and turn it on.
If this doesn't solve the problem, the printer needs to be serviced. If it is under warranty, contact Canon. Otherwise, decide if it is worth the costs for service. (You have to get the printer to the service center and then pay for the initial evaluation; the evaluation charge will be applied to the repair if you decide to have the unit serviced.)
Full descriptions and pictures of the steps to resolve a 5100 error are available from Canon support: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mg2120?CMD=MIXED_SEARCH&mName=PIXMA+MG2120&mType=PIXMA+MG&pageKeyCode=ekbresults&searchString=5100+error&BASIC_SEARCH_CURRENT_TOPIC_ID=2259&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false .
I hope this helps.
Posted on Jul 16, 2013
Arlene
SOURCE: canon pixma mg2120 error code e3
Yes
Posted on Sep 11, 2013
zodiru
zodiru
SOURCE: error p02 canon mp 280
error 5100
Posted on Oct 13, 2013
Error 2,156,50 canon mg 2120
I found the solution for 2,156,50 error message, you can read it in the link. It worked at least for my printer (Canon MG3155)
Error code 2 2156 50 on my canon pixma MG2260 printer
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
565 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
