We had apower outage and when the power came back, there is the letter A on the machne. We have reset the machine, still the letter A.
Can you help?
Cherryl Johns
Your machine is set to "Announce" instead of "Answer" mode. The announce mode merely plays an outgoing message but does not record any incoming messages.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
SOURCE: F9 Code after power outage - Model JGR8855ADS
I'm having the same problem as #2 above with the check probe message. Any Solution?
SOURCE: Fellowes UPS 425AP
where the model u using is 4 to 5 yrs so as well the battery too normally the battery life spam is up to 2 to 3 yrs and slowly the battery efficenit start to wore off.. the cost of changing the battery it also not cheap. ard 200 to 300 dollar in the market. well if you hav the in attendtion to buy a new ups i suggest the brand is APC or liebert. i recommend u the APC it will be sua750i or Liebert gxt2-1500rt230 both model is user friendly and easy to configue. and it has a very effiecent of excute proper OS shut down when power sugre is occur. and this durablity it higer can maintain up to 5 yrs above. if u need asst on what kind of ups u refer pls mi know will try to help up... thkss
SOURCE: Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
SOURCE: pOWER OUTAGE NOW THE MACHINE JUST BEEPS
find the breaker that powers it and reset it from there if that doesnt work it might be fried you'll have to pull it out to look for a fuse reset
SOURCE: Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
