Dryers Logo
Katherine Guy Posted on Apr 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sears kenmore dryer model 4179842990
Kenmore dryer zippers and draw strings get stuck in drum in the inside fins and around the door when dryer runs now sounds like pieces are rubbing around the inside of the drum. How do I take it apart ... all the directions seem to show the top style lint catcher...but mine is inside the door on the bottom of the drum opening. Also the dryer seems to be not heating consistently on the high heat setting what part could this be?
David Ellis Rhea
Level 3:
  • Whirlpool Master 3,462 Answers
  • Posted on Apr 01, 2013
David Ellis Rhea
Whirlpool Master
Level 3:
Answers
3462
Questions
Helped
786200
Points
10903
Big job.
The top comes open with a small screwdriver, or better yet a putty knife slipped to the right and left front corners and pried up. You have a plastic clip on either side of the front top which will snap open when pried.
Then, the front of the machine is usually held on with two screws that are inserted into the top front from the top sides, one screw in each side.
The bottom is easier, once the top screws are out, you lift the whole front panel off.
Down at the bottom of the front panel are two clips that go in two holes to hold the panel on.
You will also be unplugging the wire connector to the door switch.
We also had this happen, and if turning your clothes inside out or tying the strings doesn't work, we found to put such items inside a mesh "unmentionables/undergarments" bag stopped the problem.
Be blessed.
5 Related Answers
Anonymous
  • 641 Answers
  • Posted on Aug 04, 2007
SOURCE: Condenser Dryer turns but no heat
Check with multi-meter for power on the heating element's tags (115/220V). If it does get power,you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Anonymous
  • 131 Answers
  • Posted on Mar 10, 2008
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Anonymous
  • 156 Answers
  • Posted on Mar 19, 2008
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Anonymous
  • 1028 Answers
  • Posted on May 06, 2008
SOURCE: frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
Anonymous
  • 246 Answers
  • Posted on Jul 01, 2008
SOURCE: one of the fin inside
Depends on the model. The easiest one's you will be able to insert a small flat head screw driver between the front and the top panel and push on the green clips (a flashlight makes a world of difference here). With this style you just need to install a screw back in the loose fin that keeps it tight. The slightly more difficult style, you have to remove the 2 phillips screws from the door hinges and the 2 screws straight across from them. This will let you get your front panel off (remove by twisting the tops of the panel slightly and pulling) There will be 2 5/16" screws to remove that hold the top down. Same procedure, install screw in the fins to keep them tight. How do I tell which style I have you ask? Simple. If the front panel goes all of the way across at the top, it's the first solution. If the front panel goes about 2 " then the door, then another 2", it's the later plan.Message me back if you are still having trouble.
1helpful
My Kenmore Model 417.83042201 dryer ate a zipper tab and now it's scraping under the drum, I think. Is there a way that I can remove it myself?
carefully feel around the inside of the drum along the felt. with any luck you willfind the zipper and be able to remove it from inside the drum. otherwise you will have to take it apart.
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
HOW DO YOU REPAIR a arm inside the dryer that's come loose.
Hello, Typically, most dryer baffles are either installed/mounted on the dryer drum in a couple of ways:
  • from the outside of the dryer drum when assembled at the factory (remove top of dryer to get at fasteners to reattach them)
  • From the inside using fasterers such as screws covered by a small plastic/rubber cover
  • From the inside attached by means of molded in clips that secure the baffle to the drum.
In order to determine which method your dryer uses, we would need the brand and model number to locate the line drawings that would show the baffles and how they're attached.
The good news is, you can quickly and easily do this yourself by going to www.searspartsdirect.com and entering in the complete model number XXX.XXXXXXX into the model search. This will provide you with the line drawings for the dryer and you should be able to see the parts and how they are attached.
If all else fails, you can contact sears directly at their toll free phone number for assistance in finding you model number so you can get to the exploded view drawings that relate to your dryer.
Hope you find this Very Helpful and best regards!
1helpful
My dryer keeps grabbing clothes strings and zippers and catching them between the drum and door. It's a front loader. How can I repair this?
The drum slides on your dryer are worned and possibly ate away the front bulkhead and drum.
These parts keep the dryer drum aligned.
Front panel needs to be removed to determine how extensive the damage is, hopefully changing the drum slides will solve the problem.
1helpful
Clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
3helpful
2answers
Drum does not turn
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Clothing cord stuck in drum
You should be able to get the draw string completely out by trying to open the top of the dryer which may be hinged. The front of the dryer may open by prying at the front between the top and the front.
Depending on your model there should be some means of getting into the dryer to examine what is doing it. Just make sure you SHUT OFF THE POWER OR PULL THE PLUG BEFORE WORKING ON IT. SAFETY FIRST!
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
