I have ran into the flame sensor going out on units causing the same issue. Or it can be the gas coils or ignitor that can be going bad. You may have to take some time and remove the lower front panel and watch the flame and how it cycles. It should cycle on and off to control the temperature inside the unit. Watch the ignition process for at least 5-10 ignitions. If at any time the ignitor glows red and then clicks off. And the gas does not come out to ignite, then you have gas coils going bad.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles or try this troubleshooting a ge style gas dryer
