Question about Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI
Biostar GF 7100-M7 windows xp trouble
I use Biostar GF 7100-M7, already install Windows XP SP-2 then I install all the motherboards driver. but then after I reboot my PC, it theres no display on my monitor but the CPU seems running. what should I do?
    Scholar:
  • 56 Answers
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
Posted on Mar 04, 2009
6ya staff
SOURCE:
Biostar g31 motherboards usb 2 works as usb 1 in windows 7
Hello try to install the chipset driver from here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=363#dl
Select download and open the driver folder, and download the chipset driver.
When downloaded run the exe program, and reboot after the install is done.
Good luck
Feb 22, 2013 | Biostar G31-M7 TE Motherboard
Biostar Mother Board: BIOSTAR G31-M7 TE OS: Windows 7. The Intel Graphics Media Accelerator 3100 On Board Graphic does not boot on Windows 7 with Intel G33/G31 Express Chipset Family downloaded and...
Hi, you can download the driver here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Its not for windows 7 but it will probably run on your system.
X86 is for 32 bit and X64 is for 64 bit system.
Try the xp or vista driver.
Hope this will help you.
Aug 20, 2011 | Biostar G31-M7 TE Motherboard
I can't instal windows xp on this bord msi p4m800-m7 rev:3.1
Did you install the motherboard drivers first?
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=95
Did you also go into BIOS Setup, and in Boot Options, set the first boot device to CDROM?
Regards,
joecoolvette
Jul 17, 2011 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
My usb drive is very low iam already install all drivers
You need a small file from BIOSTAR that adds USB 2.o support. Go here :http://exehub.com/biostar-g31d-m7-motherboard-drivers-specs/ and go to the bottom file,download it and install it and you'll be good to go :) cheers.
Oct 24, 2010 | Biostar G31D-M7 Motherboard
Need 64 bit usb drivers for my motherboard - a Biostar G41-m7
Hi, intially when you install the chipset drivers from the website http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421 it will install the USB 2.0 drivers for you as it is already in the package. However, I now currently have the same problem as you as it seems that either a Windows Update or other software has removed this.
May 13, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
NO TENGO LOS DRIVER DE MI PC P4M890-M7 SE (VER 7.0)
Por favor intente este eslabón
Biostar
Espere que este ayude a ... por favor tase este. gracias
Mar 31, 2010 | Biostar P4M890-M7 Motherboard
Biostar GF 7025-M2 v.6.0 Motherboard Drivers For Windows XP Home
yes there are seperate versions for 32bit and 64 bit . check on majorgeeks.com for the drivers, also check cnet downloads for drivers. If the mother board is more than 5yrs old you might not find the 32 bit drivers on the manufacturer's website. also check microsoft , if they have any drivers for that motherboard. good luck
Jul 11, 2009 | Computers & Internet
Sound driver
Hi sgs182, when a driver fails to install correctly its best to install through windows device manager. Suggest you try this method of instillation before trying another HD audio driver. Also enter your bios & make sure the HD is enabled.
Either use the driver CD that came with the motherboard or download the driver from Biostar. Windows 2003 is more like window XP however we both know what you need is a driver for 2003. Biostar makes other P4M890-M7 motherboards that do support win 2003 for HD.
· P4M890-M7 TE 7.x
· P4M890-M7 SE 7.x
· P4M890-M7 PCI-E 7.1
· P4M890-M7 PCI-E 7.0
· P4M890-M7 FE 7.x
Biostar motherboards 7.0 & 7.1 audio drivers are the same file size of 24.77MB & support x86/2003 operating systems.
How to install through windows device manager?
Left click once on the start button. Slide up to & left click on control panel. Find the System icon & open it. Left click on the hardware tab than left click on the device manager button. Scroll down to Sound, video and game controller, which should already be opened. You should see a yellow explanation point here.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). (Only if you do not want to install from the CD).
Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the desktop folder
You created & named. Open it. High-light the folder that has the driver in it & click ok.
Windows will find the correct driver software within the folder & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio device within the control panel.
Mike
Sep 22, 2008 | Biostar P4M890-M7 Motherboard
Video & sound drivers - windows XP SP2
go to biostar website www.biostar.com.tw, you can find everything there..
Jun 19, 2008 | Biostar M6TSL Motherboard
Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI Logo
1,378 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
