SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD.
Using the hex key, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly
tightened, you should be able to lift each edge of the
walking belt 2 to 3 inches above the walking platform.
Be careful to keep the walking belt centered. Then,
plug in the power cord, insert the key, and carefully
walk on the treadmill for a few minutes. Repeat until
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
SOURCE: Where can I get information
As far as I know, there is no printed or e-book/tutorial available about disassembling this model. In fact, even the technicians are taught only the basics at their training sessions and they came to know how to do it only after several attempts of practices. There is either no actual method, but if you at least know how to handle the unit, you can try. Let me give you the basic step by step instructions.
And to install a new belt, reverse these instructions.
I can't recollect the exact steps but this is what I've noted down when I once worked with this model. I hope there's no mistake. Honestly I have only disassembled only a couple of times.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
