The screen just keeps on flashing number 8 when I out the safety key on. When the safety key is off incline says 14 and the time screen says 8200. Is the computer done on this?
1) replace the old battery 2) clean the contacts battery 3) adjust the REED switch, see the diagram attached, clean it, test for open or faulty, tight the connector very well. 4) LUBe the deck belt very well see the video attached. oGod bless you
the reed works. the incline motor is very hot. it will not let me select a mode. is there a way to calibrate it?
RUN THE software calibration see the details attached.The Steps for Newer Style Console Calibration 1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.) 2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed). 3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21. 4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools. 5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window. 6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window. 7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window. 8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window. 9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E." 10.Press ENTER. You should see "SS" or "55" in the console. 11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill. 12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own. 13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position. 14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use. 15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
SOURCE: Pro Form 745cs Treadmill does not incline
my sisters roller broke of the back end and detached from the plastic end can this be fixed?
SOURCE: I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
sorry not a treadmill expert. replace battery in computer or on main treadmill. i cant see the diagram for the reed switch either.
see the diagram attached.God bless you
