My washer makes a loud noise when spinning and today it started to leak water in the front.
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
SOURCE: My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
SOURCE: Whirlpool Cabrio washer is leaking water
The problem
happens when your installer throws away the drain hose u-bend, and
stuffs the hose as far as it will go down the drain pipe. When this
happens the end of the hose can get pushed under water, which causes
the washer to siphon out the wash water when it fills. This results in
an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
SOURCE: whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you.
NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
