Your dryer may not be recieving adequate voltage to start. make sure your dryer is plugged in. also check the circuit breaker panel to make sure all circuit breakers are in the right position. check fuse box for blown fuse. try plugging in something else in the same outlet. also refrain from using an extension cord.
I had the same problem, Check Filter light blinking and beeping, could not select drying type or start dryer. Short story, turned out to be the Less time button was stuck pushed in. Long story, a week before I had replaced the drum rollers and belt, everything was working fine for the week after then this problem. Totally by accident, after trying all the recommended actions (unplugging, pushing buttons, etc.) leaning on the right front corner would stop the beeping and allow the machine to work. Pushing all the buttons, I found the Less time button would not click. Apparently, when I took the control panel off to change the rollers and belt I flexed the control panel enough to misaligne the button and switch. Pulling the back of the control panel loose and making sure the push button and switch were aligned and working correctly everything works fine now.
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem. After i did this, i closed the door and my dryer started as normal.
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
There is a start relay on the computer control board. You probably hear a very dull click. That click is the relay on the computer board trying to engage, but it won't and therefore your dryer won't spin and your board sends a beep and perhaps an "E11" error code to the LED display (Not sure on Kenmores.).
In plain english, you have a bad control board now and will have to replace it. Cost about $130.
