When my Sony LCD turns on, only the initial screen with the Sony logo appears for 30 seconds. After that, there is no sound or picture. Please help me fix the problem.
SOURCE: SONY 60" KDF-60XS955 power goes off and on every 30 sec
I had this problem and ordered a new replacement
XL2200 lamp from Sony and that fixed it. By the way, the lamp installs
from the front so there's no need to pull your TV out from the wall.
Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. ou can order direct from Sony on line service.
Tom
SOURCE: picture and sound cuts off ,greem stb light keeps blinking
Tom
SOURCE: tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
SOURCE: Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
You have to get into its service menu options to do this. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now.
