I looked in the online manual and their troubleshooting section was pretty weak. Go to this website and scroll to the bottom until you find live chat. They should be able to help you this way.
Take the screen off connect power and watch LEDs if any don't flash its LEDs only needed to change faulty strip if they all flash its probably t con boards.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
If you have checked the light switch and found it to be working normally, then you will need to replace the control board because the light bulb is controlled by the relay switch. It is not directly connected to the light switch. Good luck
hold the on button on your bluetooth headset until it blink and stay
lighted then turn you cellphone bluetooth on and click search for
bluetooth device. your bluetooth headset should appear then click
connect
