Can not put lid down, stuck in the upright position on on the vacuum canister after putting new vacuum bag in.
SOURCE: How do you change the bag in a kenmore progressive
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
SOURCE: kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
SOURCE: We have a Kenmore Progressive Model 116 Upright
I suspect that you have a restriction. The motor sounds like the thermal break is stopping the motor before damage, due to heat.
You must witness that the entire suction and discharge side are clear. This is not always very easy, but necessary. I bet that you find something blocking somewhere...
