If no any power indicator at the front panel, the first thing you can do is tried to plug the tv in other wall ac socket. if still no power, unplug the cord then check for a broken wire. if ok, at this time you are going to remove the cover of the tv to check weather the fuse at the power supply get blown.
SOURCE: Mickey Mouse tv/dvd combo
Try to get other disk to read if you can not you may have a lens problem and will have to clean it. I would suggest using a fiber optic cleaning kit. You can find them on-line I beleive.
SOURCE: unlock codes
Found the code on another posting:
1,2,3,4
When the parental block comes up hit play, enter the code, then hit play again...
SOURCE: What is the password for the 20 inch tv dvd combo
Try the password 1234. It worked for my Fairies tv/dvd!
SOURCE: Just bought a new remote online for the Disney
maybe needs to be config. or your tv is remote sensor defective
