Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
Sal De
Level 3:
  • Whirlpool Master 2,699 Answers
  • Posted on Mar 30, 2013
Sal  De
Whirlpool Master
Level 3:
Answers
2699
Questions
0
Helped
1002701
Points
8029
Sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
3 Related Answers
Anonymous
  • 12 Answers
  • Posted on Mar 10, 2010
SOURCE: whirlpool thin twin dryer just beeps and wont
Does this dryer have a dial timer you set, or does it have a keypad? If it has a timer then you have a bad timer. If it has keypads, then you have bad ciruit board
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 18, 2012
SOURCE: dryer not working on Whirlpool Thin Twin
Could you check that model number again?Could you please describe the problem you are having?
Does the dryer run at all?
Check the door switch. When you push and release it you should hear a click. If not, replace with a new switch.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 28, 2012
SOURCE: Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Testimonial: "Thanks for your insight!"
My washing machine keeps filling with water
If the washer keeps filling up without overflowing onto the floor , then you have the drain hose too deep into the drain and it is siphoning, pull the drain hose back up from being so deep and have it only about 10 inches into the drain, tie it into place with a shoestring or wire tie.
Now if your problem is that the washer is overflowing onto the floor, then there is a clear rubber hose that has been disconnected from the washer, this is the diaphragm hose. Have a technician reattach it. It shuts the water off and starts the machine when its gets enough water, but it wont if the hose is disconnected. Mr Burk
Washing machine overflow on stackable washing machine
Thanks for choosing FixYa and welcome. If you have water overflowing, you need to check your water level switch. It may be bad or it may not be getting power. It controls the water level.
Machine fills with water during rinse cycle, overflowing onto floor
sounds like the drain cycle is out of sink with the timer maybe you need a new drain pump
My Whirlpool AWG5122 washing machine keeps overfilling, it seems to take in water to the point of overflowing, I have to turn the water off at the mains in order for it to stop taking water in.
sometimes if the door switch of that machine is not working so there is no auto stop of filling water. or the pressure switch may be not function well.
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
4helpful
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
