Televison & Video Logo
A
Anonymous Posted on Mar 29, 2013
Sonos play 3 won't boot
Flashing white light never goes out
roadkill1313
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Aug 27, 2014
roadkill1313
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
5536
Points
42
If power cycling (pulling power and then putting it back in) does not resolve it, and the Mute button is not also blinking green when the status light is blinking white then it sounds like a bad player. Contact Sonos Support for options on replacement.
1helpful
How do i connect sonos " control " to denon avr 300. Where are audio output on this denon?
The AVR-E300 doesn't have an audio output. It's a very basic AV receiver built down to a price.
Even if you has a better quality receiver, you still would only be able to port sound from analogue sources (ones connected via red & white RCA/phono) to the Sonos Connect for distribution around the rest of your home. AV receivers don't decode audio from HDMI sources to analogue stereo.
If you want to port sound, hook up a source direct to the Sonos Connect's audio input. Don't try going via the receiver.
Turn off demo mode for sonos
how do i unlock my sonos controller from demo mode
3answers
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
Playstation 3 cut off mid play and won't come back on have steady red light!When you hit the power it goes green blue yellow then flashing red!
Call Sony. They will fix it for you, no problem. They will ship you a "Coffin" to send the PS3 back, and if it can not be fixed, they will replace it with a refurbished one.
Jctwhen pressing the play button the light is on red it goes from red to green like it suppose to do ,but whithin 2-3 sec. it shuts itself down back to red and will not play
Unfortunately you have the red light of death (RLOD). Which means your graphics card has overheated. Repairable, but prob won't last. Mine didn't. I'm on my 3rd PS3, thankfully the slimline models don't suffer this problem.
Hope this helps.
LJ
2answers
Flashing White status light continuously
Can music be played through it? If yes, you need to just go into the zoneplayer settings and uncheck the box regarding the white indicator like.
Sonos won't play when attached
Attach the analog RCA output of the Sonos to the CD input of your receiver. On the receiver select CD is the input. Now turn the volume up on both the Sonos and the Receiver. Dont forget to make sure some music is playing on the Sonos.
Good luck
Top Sonos Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sonos Televison and Video Expert? Answer questions, earn points and help others
