GE JVM1860 Microwave Oven Logo
Posted on Mar 03, 2009
Ge profile jvm1860sf001 runs but food does heat
I have a ge profile jvm1860sf001 microwave oven. It seem to turn on and everything seems to run but the food does not heat up at all.
I have a GE sca1000bb01 microwave, it runs but does not heat. Sounds funny when running but everything else seems to work but the heating up of food. Do you have an idea as to what is wrong?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
My Ge Profile microwave runs and turns on but it is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
The microwave won't heat the food. Everything is running except and the lights are on but the food is still cold.
Seems like you have a bad magnetron and it may need to be replaced or you may just want to save yourself the hassle, and get a replacement. Hope that helps.
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
5helpful
2answers
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
6helpful
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
