SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
SOURCE: royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
