I installed new toner (Pitney Bowes 794-3) into this machine. Now it displays F2-02 error. Would greatly appreciate your help.
Thank you,
Phil
[email protected]
Sharp AR-5620N getting f-2 error. What is the solution
Sharp AR-M237 had toner replaced and worked for about an hour before getting f2-02 error. When booting up the copier will display "Toner Replenishment in Progress." Then display shows the F2-02 error code.
You need to use Sharp genuine toner.There cartridges have a 'smart chip' on the rear of the cartridge.This error code is a direct result in fitting wrong toner.
Incorrect. The PB toner 794-3 IS the correct toner for the Imagistics(formerly Pitney Bowes) ZB35 copier. The F2-02 code is a simple fix. Remove the new toner, close the front panel, turn the power switch off, and unplug the copier for no less than 30 seconds. Once the copier is powered on, do not reinstall the toner until the display instructs you to. Sharp brand toner WILL NOT work in an Imagistics brand copier.
I have the same problem...
But the Sharp genuine toner is not compatible with the IMAGISTICS machines. display a F2-04 error code
Please help!!
