COLD WATER DISPENSER IS OPERATIVE
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module. Should also replace ice maker thermostat when changing the module. Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs. If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
SOURCE: no water to ice maker
Is the ice maker turned on? The on/off switch is located on the top right side of the freezer compartment. The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full. Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
