Put in new spark plug without success
SOURCE: Craftsman Chainsaw will not start
It's your ignition, which you can take that stuff apart on the left hand side of the saw under the recoil. I have 2 of these, & you can get the parts. Maybe its just the magneto gap adjustment, which is like a business card or newspaper width gap. I would check that first. Hope this helps you, Rick
SOURCE: Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
SOURCE: My Stihl chainsaw starts up but then it won't stay running
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
Warm:
Hope this helps
Lou
