ASUS K50IJ-C1 Notebook Logo
Anonymous Posted on Mar 29, 2013
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
  • Anonymous Mar 31, 2013
    I think it is very unusual for a speaker to be replaced. If it had to be, at least it would make some sound (I think). I'll bet in bad connection, but i still think it can be a software conflict problem. Thank's for your help Lee Durbin
Toby Lee
Level 3:
  • Master 409 Answers
  • Posted on Mar 31, 2013
Toby Lee
Master
Level 3:
Answers
409
Questions
Helped
104829
Points
1133
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
5 Related Answers
Anonymous
  • Posted on Apr 16, 2010
SOURCE: hOW DO YOU ACCESS THE WEBCAM ON THE ASUS K50IJ?
http://support.asus.com/download/download.aspx?SLanguage=en-us
Anonymous
  • 10 Answers
  • Posted on Sep 01, 2011
SOURCE: I've problem with interanal speakers
It might be a cause of Loose connection or damage of your laptop speakers. Its a hardware problem. Check your Connectivity of Speakers on the motherboard. It might work!
Anonymous
  • 32281 Answers
  • Posted on Aug 08, 2012
SOURCE: asus k50ij wont boot
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Morten Rechter
  • 10 Answers
  • Posted on Feb 21, 2013
SOURCE: asus k52f laptop hdmi port no sound
Step 1:
Plug your TV into the HDMI port.
Step 2:
Right click on the audio icon on the task bar, and the click "Playback devices".
Step 3:
Choose your TV and click "Set default"
Anonymous
  • 32281 Answers
  • Posted on Mar 05, 2013
SOURCE: Bought an Asus K55VJ-SX218H notebook for college & can't connect to their wireless Internet. We've also tried connecting using cable with no luck. It connects to my home wireless but not t
You need to contact the college's IT support to get the college's wireless router configuration settings so you can configure your laptop's wireless with these settings.
2answers
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
We have older speakers that came with our computer, and we just moved and since we've moved no sound has come out of the speakers. i have checked a million times and everything's plugged in. i...
First check if the driver for your speakers is up to date. For all we know maibe something that was installed automaticaly or by some one might be interfearing with them. Go to the Window menu, click on Conrol Panel, click on speaker settings, and check to see if anything looks off (like everything is gray and you can't really select anything). If everything seems ok check all the volume settings. Remember there are 3 things that control the volume on the speakers. 1: the nob on the speakers; 2: the volume on your desktop (lower right side next to the clock); 3: the volume on the program you are using (like windows media player). Another thing to remember is some computers come with a mute button (ether on the keyboard or monitor. If your computer has a play/skip/stop buttons it most likely has a mute button. Oh, and some computers have a volume nob next to the CD/DVD player (where you put in disks). Maibe some one turned it down as they grabed to move it. Make sure it's also turned up. If they're all turned up then most likely something got bumped loose during the move. In wich case you'll have to open it up and check the conections. It'd be a good idea to test some one elses speakers so you'll know if it's the computer or the speakers...or you could try pluging in the speakers you have into something else (like an MP3 Player).
How do I remove the keyboard from Asus K50IJ ?
Try these steps:
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the Asus keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus K50IJ Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus K50IJ Keyboard component toward your laptop screen. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
I have an asus g71gx running a realtek audio driver. I've reinstalled the driver, reinstalled a new OS, and I'm still not getting any sound out of the internal speakers, but when I plug in a...
Did the internal speakers worked before? Do you use the right drivers here is the ASUS download link http://usa.asus.com/Notebooks/Gaming_Powerhouse/G71Gx/#download Maybe there is a "switch off" in the BIOS?
The last option is that it is a HW failure - if the laptop is still under warranty I would use and not try to fix it by myself
Good Luck,
1helpful
I loaned my fender passport 300 to some friends. They said they ended up using it as a mixer on a larger system. Now one speaker works normally on one output. when i switch that same speaker and wire to...
It would appear they've blown one channel on the Amplifier and one Tweeter on your Speaker. It's more than likely that the Tweeter has blown first and overloaded the Amplifier.
The Tweeter shouldn't be a problem to replace (eBay more than likely) and you'll probably be better getting a new pair and replacing them both.
The Amplifier could be a different issue depending what Country you're in and your Technical ability?.
If you need any further assistance once you've opened the unit then just ask.
Please leave feedback
Cheers
Andy
When i play an audio file my left side speaker does work but when i connect speaker to an ipod both the channels work
If the audio balance is set for the right speaker then centre the balance setting.
If it is OK then :-
This proves that the audio card on the computer is faulty and the sound comes only from the left speaker.
3helpful
P4vp-mx no sound
kindly send the motherboard cd
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
