It is likely that your battery is malfuction. So you need to get a new one. Recommend one for you:
http://www.aurabuy.com/cheap-laptop-laptop-battery-for-lenovo-ideapad-u110-11306-and-more-paypal.html
SOURCE: battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
SOURCE: Battery doesn`t charge.
the socket contacts have opened up and the plug is not making contact.with a fine flat screwdriver close up the socket contacts
SOURCE: My laptop is not recognizing
The charger is defective, not putting out enough voltage to operate unit or charge the battery, unit needs replace, check with best buy.
you could have a faulty dc jack (where charger plugs in to the laptop)
SOURCE: ASUS netbook 1005 HA charger won't stay in to keep charging battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
