SOURCE: honda varadero 1000 problem
They can be removed and cleaned or replaced.
They cannot be fixed.
They usually put out about a 0-5 volt pulse when
working.
SOURCE: Honda Varadero 125. Not starting.
Hi !
First check if the current is coming from ignition coil....
If YES ... then the spark plug is burnt(shorted) Get new plugs.
If NO... then there could be a problem with the ignition coil itself Or the coil in the dynamo is burnt.... Regards
Berry
SOURCE: how much oil to use on forks on honda varadero
http://www.repairmanualclub.com/motomanuals/index.php
SOURCE: on my honda 125cc varadero the front plug is threaded how do i sort it
If you're lucky a thread chaser may sort it...but really the best option is to remove the head and fit an insert (e.g. helicoil )
