Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Laser Class 7000 Fax won't print
Error says "Check Printer ##322"
Anonymous
Level 3:
  • Master 916 Answers
  • Posted on Mar 03, 2009
Anonymous
Master
Level 3:
Answers
916
Questions
6
Helped
282981
Points
2260
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
2helpful
Display show check printer, error code ##322
the error code ##322 appears when the fixing unit is not working. the heater does not reach the specific temperature. check the resistance of the heater, or a pooor contact . but the best solution is replace by a new fixing unit
Check printer error ##322
##322 is a common error and it is the fixing unit that's not warming up!U can have it replaced and fixed!
2helpful
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
2answers
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Check Printer error
1)need to replace the fuser unit assy.
2)this is useful link http://www.precisionroller.com/canon-laser-class-7000/products.html
3)Pls feedback me .Thanks
1helpful
Says check printer
If there is an error code with the 'check printer' then this would be more helpful. If the error code is ~ #323 then you have a laser unit fault- if it is #322 then you have a fuser unit issue. Both units are replaced as a unit.
##322 error on display
Fixing unit faulty and it can be replaced!
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
##322 CHECK PRINTER ON DISPLAY
When I boot my cannon fax 7000 I get a message :check printer" ?  Any suggestions?
[email protected]
old marine
old marine
ZJ Limited
ZJ Limited
