The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
SOURCE: How to reset the security for a Dlink DIR-625
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
SOURCE: dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
SOURCE: My router is not working.
Inorder to reset the Dlink router , please follow this steps
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Thanks & Regards,
Prema.
Get online
and got to www.google.com In the google search box type: "Dlink
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
