Re: Dispensing water and Ice
the water valve is located behind the frige, remove the lower back panel and follow the water line from the house to the frige as that line meets the frige that's the valve that may be bad,but before you change it, you can test it, remove one of the 2 lines that goes to the side of the frige and push the switch to get some water, water should come from back there, if not re move the other line, it meant that the first line belong to the ice maker, try the other one now, it should give you water. if not replace the valve.
