If the printer appears as offline in windows, consider disabling SNMP monitoring. Sometimes SNMP falsely tells windows that the printer is offline for events like "toner low, replacement not needed" and "low paper, drawer x"
Go into printers & faxes, right click on your printer and select properties, go to the ports tab, press configure port, un-check SNMP Status enabled.
SOURCE: Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
