The camera gives us a memory card error. I have firmware 1.0 and according to the website, it says to update the firmware to 1.03. I download it, however it states that it has not downloaded successfully. No matter how many times I try. Could this be because I am using Windows 7? How do I fix this issue?
SOURCE: Firmware Update
save the firmware file on your sd card, then you have to find the menu in your camera, to load it in camera memory, make sure your battery is fully charged or it will not work.
SOURCE: Memory Card Error after Formating memory card
instead of quick format, use the full format. Then put back in your camera and format again with the camera.
SOURCE: Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
SOURCE: Upgraded to Windows 7 & it no longer
HI there there try to download the windows 7 camera driver from pentax website. It will start work then. Another way is remove the memory card & put in in a card reader then you can also transfer all photos from card to computer For further help ask me . Thanks.
SOURCE: Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
