Aluminum boats are easier to maintain, will last longer than fiberglass, and are easier to repair. You can also bump into things without causing damage like you would to a fiberglass hull.
The only real advantages to fiberglass are that it looks better due to the gelcoat finish, providing that it is maintained, they also feel more solid in the water due to the extra weight, and they tend to ride better and are quieter than an aluminum hull.
One other consideration is whether you will operate it in fresh water or salt water. Salt water can lead to corrosion problems on an aluminum hull if you leave it in the water. Fiberglass doesn't have that problem, but you can have a problem with blistering if you leave a fiberglass boat in the water for long periods, especially if you don't use a bottom coat of some sort.
If you do opt for an aluminum boat in salt water, just make sure that you spray it down with fresh water and wipe it down with a soft towel whenever you take it out of the water. This is actually a good practice for any boat, aluminum or fiberglass.
Make sure you have sufficient anodes for any metallic hulled boat (zinc is best for aluminium). Fibre glass is a nicer ride for shore, but if you are the only bloke thats gonna be pulling it on the trailer (mrs wont get feet wet) or you arent planning on going in any sort of chop, ally can be better.
