I've hardly used the camera, but now there's no sign of life when I put in new batteries and slide the front cover to the 'on' position.
Resetting the camera
If your camera does not respond when you press any
buttons, try resetting the camera as follows:
1. Turn off the camera.
2. If you have an optional memory card installed, remove it.
(Although removing an optional memory card is not
necessary for performing the reset, it eliminates the
memory card as a possible cause of the problem.)
3. Remove the batteries from the camera for 5 to 10
seconds.
4. Reinsert the batteries and close the Battery/Memory card
door.
5. After verifying that the camera works without an optional
memory card, turn off the camera and reinsert the card if
you have one.
Same problem - but when I open the lens cover, the screen lights up with the HP logo, beeps then turns itself off...
thanks, but I've been through all the stuff on the HP website and it doesn't appear to be a simple re-boot problem. The camera has been used two or three times in two years, but HP are not interested. They basically said take it to the nearest service agent (100 miles away)!
Same thing here,,,,may need jtagged if possible? dunno
When I open the camera the green light comes on but the screen isnt coming on then when you close it the green light just stays on
I was trying to download the images from my camera onto my mac,
which is a whole other problem on its own, I changed the batteries
and tried to turn it on and get nothing, please help this is not my camera
does anyone have any tricks I can try?????
