Tablets & eReaders Logo
HARRY DAVY Posted on Mar 28, 2013
GOCLEVER TAB R70 INSTRUCTION MANUAL
INEAD TO DOWNLOAD THE MANUAL
B Mallon
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 29, 2014
B Mallon
Contributor
Level 1:
Answers
Questions
0
Helped
612
Points
0
GO Clever Tab R70 turned off and will not turn back on any help tried to reset it but does not help anyone else had this problem and how did they sort it???
Not getting answers to my question
25920738-fht3dh32huogwtdtesjoaok2-3-0.jpg Is this the one you have? If not what size screen does it have?
is there a model number? Support Wi Fi Tabs SM T210R Samsung Galaxy Tab
This is the link where you can download all the manuals for this version.
What is an sd card?
An SD Card (Secure Digital Card) is an ultra small flash memory card designed to provide high-capacity memory in a small size. SD cards are used in many small portable devices such as digital video camcorders, digital cameras, handheld computers, audio players and mobile phones. How to download is in your instruction manual.
Letter 'B' doesn't work on my keyboard!!!!!
You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
Q: G-SENSOR is not responding.
A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
Q: How do I restore factory settings?
A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
Why My GoClever Tab Terra 70 L won't turn on?
Sounds like you've damaged it beyond repair. Get a new one.
6helpful
My goclever tab r76.2 will not charge or turn on what do i do ?
Hi my sons tab keeps turning it self of when playing games????
How to reset my go clever tab r70
Had a similar problem with GoClever Tab R70 ; was also getting 'Ui Launcher has failed' Error ... Solved it by 1. Charging Tablet with USB power cable. 2. Using Bent Staple / PaperClip to press in reset Button at back. 3. Switch ON by Pressing and Holding BOTH Power On Button and Volume Up buttons together. This Boots up to a recovery Screen with a picture of Green Droid Laying Down with an Exclamation Mark inside a Red Triangle. 4. When you see this screen release buttons and again Press Power Button and Volume Up together to bring available options onscreen. Navigate Options with Volume Up and Down and Select by pressing Power Button. 5. If this doesn't work use paperclip /staple to reset and start again. 6. If there's nothing precious on your Tablet i'd recommend factory reset and to be doubly safe remove any microSD card that might have any data you want to keep. Thanks to this Youtuber for helping solve my Tab Problem : www.youtube.com/watch?v=jLgmptgKeNU
2helpful
I require a manual for Samsung galaxy tablet
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
