Question about Gemini Sound Products GEMINI XGA 2000 2000 WATT AMPLIFIER XGA2000
Gemini gvx-sub18p subwoofer plate amplifier dont work !
3 Suggested Answers
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: gemini gvx 15, were is
It may NOT have a fuse. If too much power was sent or an amplifier drove DC to the speaker, the voice coil may have fried. The specs do NOT brag aboput protection, so it is likely either the speaker is blown or the internal wiring is broken. Open the unit and use an ophmmeter to tesst the speakers.
Posted on May 30, 2011
Testimonial: "hey sorry for my late reply, the crossover unit was fried"
Ian Wilkins
  • 12 Answers
SOURCE: What fuse type raiting does
Nnormally about a fifteen amp
Posted on Aug 20, 2011
Have a xga 4000 amp only channel 2 works fine . Channel 1 very very low
Switch input connection pairs and if the 'fault' doesn't changes from one channel to the other it is almost certainly an amplifier or output fault.
Likewise switching the speakers. If after swapping the speaker connections the fault changes to the other speaker it is an amplifier fault. If not a speaker fault.
Aug 16, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
No sound coming from my power amplifier gemini xga-4000
I have a Gemini xga 4000 that only channel 2 works fine but channel 1 is very very low .......
Jan 09, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
New subwoofer blows fuses
you have some wires touching causing it to ground.check wiring
Dec 27, 2012 | Gemini Sound Products Gemini GVX SUB15P...
Gemini amp shut down while spinning
Could be power supply related- failing capacitors being most likely.
Could also be PWM failure- Failing capacitors being the most likely.
Output may have shorted out, or the MOSFETS or IGBT's may have failed.
Apr 01, 2012 | Gemini Sound Products GEMINI XGA 3000 3000...
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Gemini xga3000 led protection is on all the time what's wrong?
Likely have damage in the amplifier... probably the output stage. It will require servicing.
Jun 13, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Gemini gvx 15, were is the fuse located, we can't find in nor inside or outside ?
May 30, 2011 | Gemini Sound Products Gemini GVX-15 15"...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Gemini Sound Products GEMINI XGA 2000 2000 WATT AMPLIFIER XGA2000 Logo
63 people viewed this question
Top Gemini Sound Products Music Experts
Colin Stickland
Colin Stickland
Cameron Lewis
Cameron Lewis
Level 1 Expert
rhodesworks
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
