SOURCE: it doesn't turn on
Try to reset the CMOS, remove the Battery on your motherboard, its like a silver flat coin, or if you can locate the RESET Jumper, just move the jumper to short. Then try booting-up your system again.
I hope this procedure will help you.
-mrsolution
SOURCE: seeking of asrock fsb 800 prescott 800 driver
You can find & download all drivers for this motherboard at the following link:
http://www.asrock.com/mb/download.asp?Model=4CoreDual-SATA2&s=775
SOURCE: prescott 800 dual channel d4b d4a cpu cant find
Hi Pipc1,
Please be more specific on what you are looking for. A bracket? There could be 10 different things on a motherboard that you may think are brackets, if your referring to the CPU fan bracket, go to the site that has that fan, or check eBay.
Thanks
Mark
SOURCE: please help me i need
please follow and download to the below link.
http://www.asrock.com/mb/download.asp?Model=P4i65G
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
